Hemang Shah avatar image
Hemang Shah asked
MultiPlus-II 2x 120V vs MultiPlus-II
Hi all,
I have a 30amp shore power sail boat. I understand that the MultiPlus-II 2x 120V is for 50amp L1 & L2 shore power connections.
Could I use the MultiPlus-II 2x 120V even for a 30amp shore power connection? Any advantages / disadvantages? or should I just get the MultiPlus-II 24/3000/70-50 (for 24v)
Thanks
Multiplus-II
derrick thomas avatar image
derrick thomas answered ·
The 2x120 can be used in a single phase 30 amp system without issue. If you have future plans to upgrade your boat to 50 amps I would go ahead with the 2x120. If not, save a few bucks and stick with the single 120.
thamilto1r avatar image thamilto1r commented ·
Does the Multiplus II 2x120 require a configuration change to accept the 30 amp shore power or does it adjust automatically? Same question for 20 amp shore power.
derrick thomas avatar image derrick thomas thamilto1r commented ·
It will handle it automatically but you should set the incoming ac current limit accordingly.
Hemang Shah answered ·
Thanks Derrick
