David Farbacher avatar image
David Farbacher asked
Multiplus 2 Cerbo GX battery voltage discharging
img-2629.pngImage CaptionMy picture of my Cerbo GX screen shows the Multiplus charging but the batteries are only at 41%, I’ll add the RV is plugged into shore power for over a week. Months ago the system would show up to 100% batteries charged, not sure if it’s some setting or something is faulty.
Multiplus-II
derrick thomas avatar image
derrick thomas answered ·
You are in storage mode. What batteries do you have and did you configure the inverter for your batteries? Do you have a shunt installed? This is normal for storage mode, but depending on what batteries you have and how they are connected you might not have the correct system configuration.
