moach-2000 avatar image
moach-2000 asked
VRM API Token - invalid token
Hi!
I already created an User for VRM Portal.
I also created a token but I'm currently struggeling to get access to the data.
I tried to use https://vrm-api-docs.victronenergy.com/#/operations/users/idUser/get-site-id to get some results but always error 401 (Invalid token).
I also checked some other posts but still no sucess.
Any idea and/or can someone support me?
Br, Chris
api
matt1309 avatar image
matt1309 answered ·
Hi @Moach_2000
What endpoint are you using/what curl command if you don't mind sharing it.
The endpoint should be:
https://vrm-api-docs.victronenergy.com/#/operations/users/{idUser}/get-site-id
Where {idUser] is replaced with your user ID
So the curl command would be:
curl --request GET \ --url https://vrmapi.victronenergy.com/v2/users/{idUser}/installations \ --header 'Content-Type: application/json' \ --header 'x-authorization: Bearer <bearer_token_value>'
With your bearer token in the place of <bearer_token_value> and your User id in place of {idUser}
moach-2000 answered ·
Hi Matt1309!
Thanks for your support in this topic.
I used VRM Portal to do the tests in different combinations (https://vrm-api-docs.victronenergy.com/#/operations/users/idUser/installations):
--url https://vrmapi.victronenergy.com/v2/users/123456/installations \
--header 'x-authorization: Bearer <abc-123-xyz>'
e.g. 123456 = it's not my real user, just as an example. I used the userid which is visible in the VRM Portal in the URL (6 digits).
Reagrding the token - I created two new one (in the portal in the menu - access token; one was already there and I created two more) and tried both but always the same output (depends on which token I use for the try):
401 Unauthorized
{  "success": false,  "errors": "Invalid accesstoken received",  "error_code": "invalid_token"}
401 Unauthorized
{  "success": false,  "errors": "Token is invalid",  "error_code": "invalid_token"}
Any ideas?
Br, Chris
matt1309 avatar image matt1309 commented ·
Hi @Moach_2000
I think it's the User ID. I think what you're describing in the url as the User ID is actually the installation ID and not the user ID.
To get your userID try running this with your username and password ofc.
curl --request POST \ --url https://vrmapi.victronenergy.com/v2/auth/login \ --header 'Content-Type: application/json' \ --data '{ "username": "john@example.com", "password": "somepassword" }'
This will give you a new token but also tell your userid number.
