gexle avatar image
gexle asked
GUIMODS - Integrate opendtu
Hello Kevin
I installed the GUIs from you, i.e. Setuphelper GUI Mods etc.
My question I would like to install this script too.
https://github.com/henne49
Can you also copy the script into your Guimods so that I can install it here?
Can I install it without any problem so that it doesn't get in the way of your GuiMods?
Thank you
gui mods
Kevin Windrem avatar image
Kevin Windrem answered ·
This is not set up as a SetupHelper "package" so can't be manages by PackageManager like GuiMods is.
It appears this extension runs from /data/rc.local.
SetupHelper uses /data/rcS.local so there should be no conflicts if you install it as described in it's readme.
gexle avatar image
gexle answered ·
Hello
thanks can you add that to yours?
Kevin Windrem avatar image Kevin Windrem commented ·
No I can not add it. The author of the enhancement would need to make it a package compatible with SetupHelper. There are guidelines for this in the SetupHelper package if they are interested.
Performing their setup procedure should work and not cause any conflicts with any of SetupHelper-compatible packages.
