pippa57 avatar image
pippa57 asked
ESS relay test pending
After re-connection of PV cables ESS relay test pending appears on Advanced submenu and seems 'stuck' ? batteries 100% charged.
As in a previous post, inverter blocked, ESS off and system in pass through mode.
As a complete novice I have read previous posts but none have been of help. Is it possible to manually activate test through victron connect? or by other means.
Any suggestions in simple terms would be appreciated.
Multiplus-II
