scottthardin avatar image
scottthardin asked
Toggling off Charger enabled setting
Regarding SmartSolar controllers, the battery setting Charger enabled says to only use in maintenance mode. I realize solar and shore power charging can coexist but would it hurt anything to shut down solar charging via this setting so that only shore power charging is being applied to batts?
charger
markus avatar image
markus answered ·
you can do this. No problem.
Regards,
Markus
