George Grammatikoglou avatar image
George Grammatikoglou asked
Attribute codes meanings
I do a get request for my installation and i get data for some attributes (e.g. Pdc, bv, bs) but i dont know what they mean exactly. For example Pdc is the Current Power?
Moreover, is there a list for all atribute codes and what do they mean?
For example the json contains:
"totals": {
"Bc": 6.658641815185547,
"Bg": 0.026947021484375,
"Pc": 14.463402848690748,
"Pb": 8.77824854850769,
"Pg": 18.278285451233387,
"kwh": 48.20552568510175
the meaning of Bc, Bg, Pc, Pb, Pg can be found somewhere?
api
amm avatar image
amm answered ·
Hi.
I'm asking the same question.
All attributes are described in the answer to this query:
https://vrmapi.victronenergy.com/v2/installations/{idSite}/diagnostics
TLDR:
"code": "Pb","description": "PV to battery",
"code": "Pg","description": "PV to grid",
"code": "Pc","description": "PV to consumers",
"code": "Gb","description": "Grid to battery",
"code": "Gc","description": "Grid to consumers",
"code": "Bc","description": "Battery to consumers"
"code": "Bg","description": "Battery to grid",
Only I can't found answer for "kwh"
Regards.
fjaehn avatar image
fjaehn answered ·
thank you for the helpful information.
When requesting the "Installation Stats" API without any "type", I get the following.
What does Pdc, bs and bv mean?
... "totals": {
"Pdc": 4345.057729672401,
"bs": 69.25,
"bv": 99.98400000000004,
"total_solar_yield": 2.06005859375,
"total_consumption": 0.29127073287963867,
"total_genset": 0,
"grid_history_to": 0,
"grid_history_from": 0,
"iOI1": false
