Dean Perry avatar image
Dean Perry asked
Odd 1s or 2s Error #67 on only one MPPT of 3
The system has 3x SmartSolar RS450/200 side by side with CAN daisy chained then about 6m of cable to Cerbo. Terminators on both ends.
The _middle_ RS450/200 throws a little flurry of Error #67 for one or two seconds each (maybe half a dozen a day). Then everything works fine.
Cabling has been checked, connections plugged and unplugged (because RJ45s :-/ )
Not really sure what to try next - the customer doesn't want the errors and the system didn't always throw them. Not sure what changed - other than the system, which has several Quattros, is now in active use (so ambient electrical noise has increased). I know noise/reflection issues can be weird.
Going to try no termination, just one end etc. Contemplated split-terminations (with a capacitor in the middle) in case it's a particular noise sensitivity issue.
Suggestions?
VE.Canrs450
nickdb avatar image
nickdb answered ·
Is the data cabling run separate from power cabling?
Assuming cables are good it could be interference.
Mucking with terminators isn’t a good idea if you already have issues.
Dean Perry avatar image Dean Perry commented ·
They're in separate ducts but yes, not that separate. Crossing 90° to DC cables etc.
It may just be that I'm old and paranoid but the errors appear to correlate with spikes in the load.
derrick thomas avatar image
derrick thomas answered ·
Are you only using one can port on the cerbo? If so try moving the offender to the second can port by itself. You wouldn't think it would matter but I have seen stranger things happen. Don't forget to place the terminators appropriately.
