stellaroverland avatar image
stellaroverland asked
multiplus 6/3 wire fittment
This is brand name 6/3 triplex wire, which is manual spec to handle power assist loads.
The strain relief does not fit.
What am I doing wrong?
Multiplus-II
stellaroverland answered ·
*Zip Ties are a temp solution
Rob Duthie avatar image Rob Duthie commented ·
Seems then cable is to big, 6 is 16mm2, what size inverter is it? not mentioned ?
Its a Multiplus II 2000 80. The cable is 6/3 marine triplex.
12,24, 48V inverter?
stellaroverland avatar image stellaroverland Rob Duthie commented ·
12V
The manual specs 6/3 wire. So, ... wire size is correct.
JohnC avatar image
JohnC answered ·
@StellarOverland
Try paring back that outer sheath so the individual cables can lay flat. They're the ones you want to clamp, not the whole assembly.
stellaroverland avatar image stellaroverland commented ·
The cables do not fit into the bottom hole opening if flat.
They also do not fit flat into the strain relief. The strain relief is only wide enough for two of them.
stellaroverland avatar image stellaroverland stellaroverland commented ·
If flat, the cables span the entire width of the strain relief including the nut and bolts.
seb71 avatar image
seb71 answered ·
Try arranging the wires so that the middle wire sits on top of the other two wires.
Like this, when viewed from the bottom of the inverter:
   X     X
   |  O  |
   |O   O|
X - nut
O - wire
