usernamepasswordbs avatar image
usernamepasswordbs asked
Delay inverting after grid loss rcd trip
I am currently having a problem with the main RCD on the incoming grid tripping out but what I am asking about here is why after resetting the RCD all loads are supplied solely by the grid for a good 2 minutes or more and only very slowly revert to PV/ battery. When this happens the PV power goes only into the battery.
Set up is a MPII, RS450, Cerbo, Pylontech. The loads in question are on AC1.
Thanks.
Multiplus-II
nickdb avatar image
nickdb answered ·
This is normal behaviour after grid recovery, it is also influenced by the grid code settings.
I edited the grid code parameter and mine phases back a lot faster now.
usernamepasswordbs answered ·
Oh right. A bit annoying for me at the moment.
How do you go about editing the grid code ? It says I need a grid code password.
derrick thomas avatar image derrick thomas commented ·
Probably nobody is going to post it here, so Google is your friend.
Thanks very much.
Out of interest, what would be the danger of reducing the "reconnect after trip" delay from 60s to 15s ?
Non-compliance and severe finger waving from men in grey suits.
Oh no! Not that!
So, the reconnect of ACout2 is now pretty quick but it still takes a few minutes (more than two) for the inverter to supply the loads. It very slowly increases the PV /battery component, not linearly, just goes up and down by a hundred watts or so and eventually gets down to the target grid supply of 50w.
Is there a parameter I can change to improve this delay, even just temporarily until I work out what's is tripping my main RCD?
Thanks,
