Willem avatar image
Willem asked
Quatro 15000 48 permanently in overload
Hi
A Quatro 48/15000/200 installed by myself brand new
operated for about 30 minutes went into overload
Resetting with the switch does not work
Disconnected from the load and the feed switched off completely disconnected the battery
reconnected the battery only
Goes into overload almost emediately
I suspect a faulty unit
I have installed many of these and this will be my first failing basically out of the box
alarm
Willem avatar image
Willem answered ·
The Quatro was formated with new firmware 2625505 and resetted to factory defaults but still goes to Overload immediately once switched ON
this hapens on battery and or grid feed with NO LOAD connected to it
Hi @Willem,
Sounds like a fault to me too. The next step is to get in touch with your supplier.
https://victronenergy.com/support
Willem avatar image Willem commented ·
Thank you I already requested a RMA and will hopefully soon receive some feed bacl
