Hi all,
I try to figure out if a constant load around 3.2kWh-3.5kWh will be an overkill for Multiplus ll 12/3000? Any ideas if this will damage the unit?
Thanks for help
Hi all,
Thanks for help
That will require a complete change of the battery bank which I would like to avoid off course
Recommended Cable lenght under 1m and at least a H01N2-D 70mm2 which support 341A S1. A H07Z-K with 70mm2 support only 270A AFAIK.
88 People are following this question.
