ok guys i have a customer with a multiplus generator has stropped charging batteries, however it will start up when voltage gets low. just doest put power into batteries . it does help with high loads to ac however. im stumped
Just to be clear, the multi will pass power from the generator thru to the output but simply will not charge batteries? Has the multi recently been updated? If so, the settings may need to be adjusted.
87 People are following this question.
