ivica avatar image
ivica asked
Two MultiPlus in parallel
If I have two Multiplus Compact 800VA on the separate batteries (two separate systems; solar system and wind system), can I put their AC output in parallel (they aren’t configured parallel) and make micro island grid? Can I control them by external 3-way switch (one on, one off, or both on) and do they always divide load fifty-fifty?
Thanks for your support!
Ivica
MultiPlus Quattro Inverter Chargerbattery charging
wkirby avatar image
wkirby answered ·
No, you cannot connect MultiPlus' in parallel unless they are configured to work in parallel via communication cable. Their outputs will be out of phase and there will be a problem.
When you configure two MultiPlus' in parallel, they must come off the same battery bank, with identical cabling - more information here - https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
