I recently purchased 12 100ah victron smart batteries but the supplier made a mistake and included 12v/200ah. Kindly help me how I can connect these
@atwijukye@mrc.gm You have a generous supplier in giving extra battery capacity .
You will need to read the Lithium Battery Smart manual. to learn how to pick a BMS that will suit your battery usage.
You must use a BMS with the LSB to protect the battery from destructive over / under voltage situations, and cell damaging temperature extremes.
@atwijukye@mrc.gm Following the Series / parallel section LSB manual, you can not use different capacity or different model batteries in a series string.
38 People are following this question.
