alain24 avatar image
alain24 asked
Mppt control display with a shunt? And connection to a PC.
Greetings,
Can I use the MPPT control display to monitor my solar array AND add a shunt to monitor my battery banks to avoid adding a BMV712?
The manual says the following but it is not clear to me what it means:
( https://www.victronenergy.com/upload/documents/MPPT_Control_Display/MPPT_Control_display_manual-en.pdf ). P.8.
Load output state Load output switched on or off. Only visible on MPPTs with a load output.
Load current The current into the load. Only visible on MPPTs with a load output.
Load output, do they mean a shunt?
One last question:
Is it possible to output this information to some software on my PC?
(Namely Open Plotter on a Raspberry Pie)
Thank you all!
Alain
MPPT Controllers
seb71 avatar image
seb71 answered ·
No.
Smaller Victron MPPTs have a dedicated output labeled "LOAD" (besides the Battery and PV terminals).
Those lines you quoted from the manual are about that LOAD output.
I don't know if that's possible.
You can use a VE.Direct-USB interface and VictronConnect software on a Windows PC.
The ready made option for monitoring any Victron system is to use a so called GX device (such as Cerbo GX).
But you can make your own GX device using a Raspberry Pi, on which you install Venus OS (from Victron).
https://github.com/victronenergy/venus/wiki
If you do not already purchased the MPPT, make sure you get a "Smart" Solar MPPT (not a "Blue"Solar MPPT).
For Victron equipment, "Smart" denotes built-in Bluetooth (not "Blue" as you might expect; "Blue" is much older naming).
SmartShunt also has Bluetooth.
Having such a pair you can access them with a phone (via Bluetooth), so maybe you don't need any other display.
Also with both having Bluetooth, you can use something called VE.Smart Networking:
https://www.victronenergy.com/media/pg/VE.Smart_Networking/en/index-en.html
Note:
If you include a GX device in your system, then do not use VE.Smart Networking, too.
A GX device gives you much more, but VE.Smart Networking has no additional cost (if using the correct components).
