Multiplus II,
”Mains On” on
”Bulk” on
”inverter on” flashing.
The unit is likely in bulk charge state and power assisting.
But a few more information about the system could help.
Mine is doing the same as the one in your distributor’s video https://www.youtube.com/watch?v=xHQGOfSGQd4
Please give us some more information about your system.
MultiPlus II, CerboGS, ESS, grid parallel, external current transformer, exactly the same as the one in the video, supplying a grid connected load and avoiding export.
On the GX, under device list the ve bus state should be shown there.
So, If I want to know what it is doing, and I look at its LEDs and BULK is lit, it could either be doing bulk charge, or it could be doing grid-tied inverting, it is almost impossible to tell unless I fetch my iPad, run the Victron connect app, change the source of my wi-fi and log in to the remote console.
Really?
I am very pleased that I installed analogue volt and current meters on the battery.
Well the GX is really designed to be used with a screen. And if you connect your GX to the wifi, the remote screen is available over the local network.
In fact you can use the ip address in a browser and skip the app completely.
The leds you described is usually when the inverter/solar is grid connected thr battery is in bulk state and the solar is aiding loads. So ESS.....Additional resources still need to be added for this topic
40 People are following this question.
