Franc avatar image
Franc asked
Phoenix 12/2000 installation question
I am in planning stage of installing Phoenix 12/2000VA on my boat. Boat has 3 x 200 AH LFP batteries. Each battery has 80 A circuit breaker, meaning max 240 A. As inverter heaviest load will use 1250W of power, 240 A is acceptable limit for us. Question: Do i need fuse on inverter cable, manual recommends 300 A, as already have effectively 240 A fuse on house battery?
inverter current draw
kai-fuchs avatar image
kai-fuchs answered ·
I think your current setup should be ok, more fuses don’t hurt. But there should be no scenario where this 300A would Trip first.
kevgermany avatar image
kevgermany answered ·
Fuse positives as near the source as possible. The positive from the phoenix to the batteries is effectively unfused until the cable reaches the fuses on the batteries.
kai-fuchs avatar image kai-fuchs commented ·
Isn’t the phoenix the load not the source? I believe Franc refers to a Phoenix Inverter, not a Charger. Therefore it should be fine
