I’ve noticed that even after specifying the correct Ah that after 10 days of battery remaining it goes to infinite. Is there a way to show higher than 10 days remaining?
No & 10 days is a long time so it would probably not be very wise to base the time to go for 10+ days based on the instantaneous usage currently occurring.
Mark,
understood, but 10 days being a “long time” is purely subjective without knowing my application. is there a technical reason why it can’t show more or just purely a soft limit?
Understand/agree - its just a simple calculation so I would think that the 10h max display limit is only a reasonable decision that Victron made.
I hope that you understand that during periods of battery charge, infinite time to go is obviously the only correct answer. As if that state was maintained then the battery would never discharge.
8 People are following this question.
