Hi everyone,
I’ using the IP22 charger as power supply.
Is it correct that the charger make again the step charge sequence, absorption-float-storage, when I plug in it.
I'm not sure how you would use the IP22 as a power supply without battery connected, but I've just installed one to charge leisure batteries on a boat and it works as a power supply with batteries connected. Overnight it went through the stages and checking it this morning arrived at storage mode. I've used fridge, radio, diesel heater all day and you can see the current they draw via the Bluetooth app
I think so long as the current drawn by your dc appliances does not exceed the current from the charger (mine is 15a) then in effect you are using the charger as a power supply as the current is drawn from the charger rather than depleting the batteries.
9 People are following this question.
