corkery avatar image
corkery asked
CANBUS BMS-Color GX-Multiplus-Lynx Shunt
I'm installing a Canbus BMS LFP battery. I have a Multiplus and 3xMPPTs. All current is monitored via a Lynx 1000 shunt. Enabling DVCC will control charging from Multiplus and solar/MPPTs I believe. However I'm unclear if the consumption/charging monitored by the Lynx and reported to the Color GX is included in the calculations for charging/discharging. Description in section 14, Particulars, Item 3 of Color GX manual is ambiguous. For instance, I have alternators that charge via the shunt but do not talk directly to the Color GX. Likewise none of the loads report directly to the Color GX but are all connected via the Lynx. So the question is under DVCC what role does the Lynx 1000 play and will the Color GX do the calculations to net out all currents when responding to the Canbus BMS requests for charging?
DVCC
