iikka-salmi avatar image
iikka-salmi asked
Correct inverter for freshjet 1700
I would like to use my freshjet 1700 AC while driving and I would need to have an a correct inverter for it.
The https://www.dometic.com/en-se/outdoor/rv-and-van/rv-air-conditioners/dometic-freshjet-1700-20699
States it needs the following:
Power consumption - Cooling mode (ISO 5151), [W]
620
I would like to go for. Small rather than larger 12v charger inverter. The dometic should also have built in soft start.
What would be correct Victron multiplus for the job?
Thank you!
Multiplus-IIaircondition
