Matthew C avatar image
Matthew C asked
ET112 AC energy monitors not showing after upgrade to Venus 3
System is 2 x ET112 (1 is non victron AC-PV charger monitor, the other an AC load monitor), Victron SmartShunt (battery monitor) and a Cerbo GX.
Since the OS auto updated to v3 the ET112-based info is not showing up on the remote console or VRM.
I have confirmed that everything is showing up in the device list and I've reconfigured the ET112 as a PV & load monitor (it seems like this config had been screwed up).
Any tips as to what's going wrong? Another post alluded to temporarily plugg in an MK3-USB dongle (to make the OS think there's an inverter maybe?).
Cheers, Matthew
et112 pv readings
Matthew C answered ·
Still no luck with this! Does anyone have any ideas where to look?
I don't understand why the energy meters show up in the device list but not on the dashboard / VRM.
I tried plugging in a MK3-USB adaptor.
I guess the next thing to try is downgrading the OS to 2.94 - is there any info about which version broke this functionality? Maybe Victron should test their updates more thoroughly before releasing them FFS
Juraj Nikolov avatar image Juraj Nikolov commented ·
@Matthew C
Stupid question, but I'll ask anyway :)
It measured before ? Or did you upgrade venus and then connect as new devce ET112 ?
If you connected it additionally, the question is whether you have connected the RS485 - USB converter correctly.
Or if you use USB-hub, if it has power :)
If yes you can try to use STC013-000 100A/50mA for 1phase mesuring ;)
In any case, it should be able to measure through the multiplus even without these external gauges.
