In the summer, I would like to charge my batteries after 10 a.m. so that the inverters do not run into their limit.
Please @Victron include it in an upcoming update if possible.
Thanks
Thanks
hello,
you can control some parameters with nod-red to prevent the inverters from charging or you can limit charge current with an external circuit and an assistent for charge control. i use this to switch charge current from min to a specific value.
you can use the relais of the gx-device to do this.
i also missing a setting, to control the charge-current from node-red.
goodby
you could use the 2 wire BMS assistant, and a simple switch to do this.
36 People are following this question.
