Upgrading from 3.10~9 to 3.10~12 and 3.10~15. Both 3.0~12 and 3.0~15 are missing the I/O Bluetooth sensors settings. Venus OS is not picking up Ruuvi B/T sensors. Reverting back to 3.0~9.
B/T sensors work for me with v3.10~15, Cerbo and an external bluetooth dongle. I/O / Bluetooth menu is there also. Shows both internal and external bluetooth adapters.
RPI test system also shows the I/O / Bluetooth menu and shows the internal adapter. No sensors attached to this system however so can't test that aspect.
39 People are following this question.
Read voltage data from "SmartBatterySense HQ2217UFGHD" via bluetooth on linux.
Venus OS and Data Collection from Victron Device(S)
Persistent Bluetooth Controller Crashes with Cerbo-GX v3.00
Smart Solar won't connect to Venus OS on raspberry pi
Can you use beagleboard to store the data from the Mppt 75/15 blue charger?
