wannibi avatar image
wannibi asked
ESS Throttling
I have noticed lately that if "Optimised with battery life" is enabled, and the doc limit is set to 80% for instance and the batteries is at 50%, the MPPT throttle output to match only the max charge current and the source the load power from the grid. As soon as I lower the limit to 50% or below, the MPPT throttle up, and charge the batteries with the same power as before as well as the loads. Am I missing a setting somewhere? I have played around with "without battery life" and this do not change anything.
MPPT ControllersESSess settings
Juraj Nikolov avatar image Juraj Nikolov commented ·
@Wannibi
I had the same problem.
In my case, upgrading MPII to ver. 505 is fixing this problem (charging and discharging batteries from / to grid)
But I rather think that somewhere in the firmware there is a bug in how MPII evaluates the AC-in & AC-out measurement and then it goes crazy :)
Check what values the MP shows you and measure it with a clamp ammeter :)
I'm guessing that the clamp ammeter will have different values than the MP, it will show quite differently :)
gabius avatar image gabius commented ·
Same issue, I’m not the only one reporting it, but the answer is « your configuration must be false » anyway it worst without trolling if I stay under 1400w.
So nodered, and when more than 1400w inverter mode only.
It fixes it by now
