le-promeneur avatar image
le-promeneur asked
Multiplus 2, inverter stakes it is okay but no voltage in ac 1
Hello.
I have a Victron multiplus2 48-300-35, lithium batterie 61v (within the multiplus range) no optional temperature nor voltage sensors.
i can start the inverter, the green light is continus, veconnect tells that the inverter produces 230V but no voltage on the.ac out 1
Additional information, it is the first start it Is like a short cut betwee ac out 1 life and neutral, when I put charger only (with no ac in) nothing happens either., No ESS. What could it be?
