fhorn avatar image
fhorn asked
Blue Smart charger change to power supply mode using Mode button
Is there any way to change a Blue Smart IP22 charger to Power Supply mode using its front panel, for example its Mode button, instead of having to use the app? Once in Power Supply mode, it can be turned back to charge mode by pressing the Mode button but I’d like to be able to get into Power Supply mode also from the front panel.
If using it as a power supply at 12.X volts and accidentally press the Mode button, then it will change to charge mode and output 14.X volts which for some situations might be too high.
bluesmart ip22
