Hello Guys
Can you parallel a 15kv Quattro and a 10kv Quattro together ?
Hello Guys
Thank you , I have Six 10kv Quattros in parallel 3 phase setup ; can I remove a phase of 2 and replace with 15kv and still have the system synced up as a 3 phase unit , 2 phases will be 20kv each with two inverters and last phase will be 15kv with one unit ?
69 People are following this question.
