jcottis avatar image
jcottis asked
Orion DC to DC Converter for Lithium Batteries
Hello, I am installing a new lithium battery into my boat and for alternator charging from the start bank to the house bank I accidentally purchased an Orion 24/24 17 DC to DC Converter not a DC to DC Charger. Can I still use the Converter to charge my new Lithium house bank battery or do I really need the Charger?
Orion DC-DC Converters not smart
Alexandra avatar image
Alexandra answered ·
@jcottis
Most ideally you want the charger.
You can fudge it with the converter, you just won't have the three stage charge just a constant voltage. For lithium that is not totally terrible.
Set it a bit lower than the max charge voltage bit above float for the battery.
The amps will stop drawing when it is close to full. Maybe have a way to disconnect by remote as well unless you need it (battery) as a power supply as well.
Both @WKirby and @JohnC had some good points here.
jcottis avatar image jcottis commented ·
@Alexandra thank you for your reply
