tijn1974 avatar image
tijn1974 asked
Question about a setup of 3 multiplus (off-grid) and a separated multiplus for feeding gen/windgen
My current setup exist out of 3x Smart solar RS's, 3 Multiplus II 10kVA and 58kWh of Pylontech battery's, and a Cebro GX. The setup is off-grid.
Im now thinking thinking about adding a small multiplus or quarto, for example the 5kVA version with als only reason to charge the battery's on a alternative way with a 230V wind generator or in case of emergency a normal generator.
Is it possible to use the Multiplus or Quarto for this purpose, and would it interact then with the Smart Solar RS and the Pylontech BMS system?
Multiplus-II
