The Multiplus monitors the DC input voltage and will shut down the inverter; let‘s say this value is 10.5 V
The BMV 712 with smart shunt has a low voltage relay setting of equally 10.5 V. The said relay controls the Multiplus.
There is a discrepancy between the two devices hence the Multiplus may assume a low voltage scenario whilst the BMV continues with the relay open.
Do you agree the BMV measurement is more accurate and that I can set the Multiplus DC low voltage to reflect this difference?
Many thanks
