hunterbyname avatar image
hunterbyname asked
sanity check MulitPlus2 48v/5KW with Nissan Leaf batteries
i'm still new to power wall/victron units and this is the first one i've built so i just want to sanity check my settings
the intention is to charge 4 sets of nissan leaf batteries run in a 14S configuration, each pack has it's own Daly BMS . with the excess solar power charging the batteries during the day.
i want to check that my Vicron setting are correct, Victron Settings.txt??
thanks for the help/support
Multiplus-II
hunterbyname answered ·
helps please
Rob Duthie avatar image
Rob Duthie answered ·
Hi
These will giev you better usage of battey capacity etc, this what i have used in the past and works well.
The main thing is to have a well balanced packs.
DC input shut down 42v
DC input low restart 44v
DC input pre alarm 44v
Absorbtion voltage 57.40
Float voltage 57.39
Charge current to suit
Regards
Rob D
NZ
hunterbyname avatar image hunterbyname commented ·
I posted my bms settings should I adjust them?
Thanks Rob,
Hiu
Yes i thinks so. to match the victron settings.
