intergalactic avatar image
intergalactic asked
No AC Out Connected to Shore Power MultiPlus 12|3000|120
I have seen this question asked without an actual response or update if there was a resolution. Inverter is in ‘On’ mode, not ‘charge’. Everything functions normally drawing from batteries. Invert light is on, and AC out functions normally. Plug into shore power, inverter kicks off, and there is no AC out. On the MultiPlus the inverter led goes off, and the mains led and the appropriate charge led come on. No AC out. I have a MultiPlus 12|2000|80 in another build, and it functions perfectly. What needs to be changed to make this properly function?
Multiplus-II
