pierbiag avatar image
pierbiag asked
Wrong Device Type in sections of VRM and Remote Console - Charger possibly not working
Please help! I'm desperate!
My Multiplus compact 12/2000 was replaced by my dealer because of a hardware issue. It looks like the new device is correctly considered as a multiplus in device list, but not recognized as a multiplus in the remote console and in parts of the VRM, but as a Phoenix Compact Inverter. It's a remote installation so I have limited access to it. The VEConfig file is also opened as a Phoenix.
The charger and pass-through functions also don't work, but I can't physically go and measure voltages.
The device is definitely a Multiplus from the front panel. Below is the serial number if it helps:
Thank you in advance!
Pier
P.S. I've already rebooted the Cerbo and asked people on site to switch the Multiplus off and on
pierbiag avatar image pierbiag commented ·
Update 1: I've updated to the latest firmware and this did NOT solve the issue
Hi @Pierbiag,
The best thing to do is get back in touch with the service centre that repaired/replaced your warrantied unit.
I think what might have happened is that there are some circuit board parts that are commonly shared between models, and then can be 'upgraded' via a firmware upgrade if the rest of the hardware is in place.
Edit - note this is different to a firmware update, and will most likely involve some additional advice from Victron via the service agent
It is only a guess that fits what you describe, and regardless the thing to do is get back in touch with your service dealer with your report.
Sorry about the inconvenience - it MAY be possible to remedy without returning the unit if you have an MK3-USB - but must be done in concert with them.
Thanks Guy, I've given a call to my dealer who will give it a look and refer it to support. I've given him the link to this thread so they can access the attachments
