The firm that sold me the new us3000cs and cabinet etc., tell me that I need to use 128 euros worth of bus bars, as the connections in my Quattro are overloaded. Is this right? Here we have a photo of how it is right now (and has been for 8 years):
Yeah. That’s not really how they are intended to be used. The wiring unlimited doc is pretty clear.
Its one of those “just because you can, doesn’t mean you should “ moments ;)
Not the worst I have seen, but yeah.
Skip the battery cabinet and get the bus bar instead if budget is an issue. It is way more important.
It will allow better set up for current share on the battery bank as well. If you are planning on one big stack or even two then current sharing will become an issue.
Thanks all. I already have the busbars as they were shipped with the batteries and cabinet (flat pack). I'll fix them to the wall tomorrow and connect the lithiums to them. Then we're all ready for a quick changeover.
The thinner wires are from MPPTs? Do you have fuses for those?
Yes, the wires between the busbar and the MPPTs should be protected by separate fuses (each positive wire). As close as possible to the busbar.
The wires between the inverter and the busbar should be protected by fuses (positive wires).
The wires between the battery and busbars should be protected by fuses (positive wires).
In general, anything connected to the battery (directly or via a busbar) should be protected by a fuse (on the positive wire).
All fuses are sized according to the wire they are supposed to protect (meaning the fuse should burn well before the wire if the current is too high for that wire).
68 People are following this question.
