Hi
I use the ESS mode for my multi plus . But the Inverter switches of when SOC is below 50 % and the Grid in disconnected, even though minimum SOC is sett to 35 % How can I change this?
Hi
You will need to look at the programming on the inverter itself.
It will either be the dynamic cut off in ESS assistant or the shutdown on the inverter tab when using ve config.
67 People are following this question.
