Shaun avatar image
MultiPlus 2 Certificate VDE-AR-N 4105:2018-11
I would like to build a installation with a MultiPlus 2 and ESS in Germany.
I have now learned that all inverters since 27 April 2019 must have VDE-AR-N 4105:2018-11.
But i only found the "Certificate VDE-AR-N 4105 MultiPlus-II and MultiGrid-II 48/3000".
Inside it says "VDE-AR-N 4105:2011-08".
Someone can tell me if I can build that up and register with the existing certificate.
Or do I have to wait for a certificate with "VDE-AR-N 4105:2018-11"?
Suggestions welcome. Thanks.
Multiplus-II
Shaun avatar image
The new certivicate is published,
and i now have a installation in germany with Multiplus 2 in operation and registered with the new certificate.
Everything worked well.
Share
Bob (Victron Energy Staff) avatar image
Hi Shaun, we're working hard on the new certificates, although I can't give you a timeframe when it will be ready yet. For new ESS installations which were not planned and scheduled in advance of 27th april you now need the new certificate.
2 comments Share
@Bob (Victron Energy Staff) Is this certificate also needed for a new ESS installation in the Netherlands? I'm planning a DHZ ESS installation and I was wondering if I could use a second hand Multigrid 48/3000 for that purpose.
Dear Evhaandel, unfortunately I can not advise you here. Please contact a Dutch dealer to check if the available certificates work for the Netherlands.
