jaconradie avatar image
jaconradie asked
Newbie need help with Multiplus 24/3000/70 battery seup 2 x LifePO4 Batteries (24V)
I am newbie to Victron inverter battery setup, I need advice to setup 2 x LifePO4 Batteries 100AH (Hubble Brand) in series for the Multiplus 24/3000/70 Inverter. I selected Lithium Iron Phosphate (LifePO4) in the Victron setup and the default settings are as follows
Multiplus Settings (for the 2 Batteries in Series)
- Absorption Voltage 28.4V
- Float Voltage 27.00V
- Charge Current 20A
- Repeat Absorption Time: 1Hr
- Repeat Absorbtion Interval: 7 days
- Absorbtion Time: 1 Hr
Label on thelifepo4-label-settings.jpg LifePO4 Battery-----------------------------------------------Equalized Voltage : 14.4V
Float Voltage: 14V
Cutoff Voltage 12.2V
Max Discharge Current: 100A
Any help will be appreciated
Thanks
Multiplus-II
Alexandra avatar image
Alexandra answered ·
@jaconradie
It will likely be 2x the voltages shown
Equalisation (for lithium is absorption/bulk)
2 x 14.4 is 28.8v (if they trip then you can lower it.)
Float
2x 14v so 28v.
Cut off
2x 11.2v so 22.4v. but i would run that a bit higher, at about 22.8v or 23v. So the inverters shut off before the batteries.
Obviously on the lithium profile as you said. The rest looks good.
Capacity is 1.2kwh
jaconradie avatar image jaconradie commented ·
Much apreciated Alexandra
