Steve Bigham avatar image
Steve Bigham asked
Another Fault #40 Whats the solution?
I’ve not seen a response to this fault. My solar is off line and I cant reset it. Is this broke or is this correctable. I’ve checked the connections, de-energized the system. How does this fault get created or set? What are the possible causes of this fault?
MPPT Controllers
nickdb avatar image
nickdb answered ·
Sounds like an RMA is needed.
https://www.victronenergy.com/live/mppt-error-codes#err_40_-_pv_input_failed_to_shutdown
The explanation ends with the charger will become faulty.... Send it back for an RMA.
