jronan avatar image
jronan asked
48v PV to 12 DC System
Morning,
I've been handed a 225W/48PV Panel, and ideally would like to use it to charge a Victron 12-38, could a Victron MPPT 100/20 be used for it? I appreciate its probably overkill. Its for an environmental sensor going to be left out 24x7x365.
Thanks
John
MPPT Controllers
matt1309 avatar image matt1309 commented ·
Yes you need a charge controller on the PV and I believe that Victron one should work.
Alexandra avatar image Alexandra ♦ matt1309 commented ·
Or a 75/15 mppt.
pekkaj avatar image
pekkaj answered ·
Depending on the model, 225W panel could produce almost 270W on ideal low temp condition. 270W/12V = 22,5A. So theoretically 100/20 is not enough. But if always in warm temp or otherwise non ideal conditions, it's ok.
