Steve avatar image
Steve asked
Mppt tile disappeared, deleted device won't reload on ccgx
Hi.
I have an easysolar 2 gx, running from 4 x us 5000 pylontech.
I.ve upgraded the firmware, but have lost the orange PV tile, which has been replaced by a green DC tile which registers -(minus)watts when charging by solar.
The mppt is connected by ve direct cable.(I ve swapped to ve 2 to check).
The BMS goes to ve bus with port terminator.
The baud rate is changed to 500 kbps.
I deleted the device from vrm, and now I can't get it back after reboots/power down/firmware updates .
I have also noticed that even though the system recognises the pylontech batteries, they do not show as externally controlled.
I wonder if anyone else has experienced/solved this problem?
Cheers.
Steve.
MPPT Controllers
