cramik avatar image
cramik asked
PV inverter disappeared from CerboGX console
My PV inverter (SMA SB 4) has always appeared correctly in the console. From yesterday, it disappeared. Victron multi and the SMA are on a local hard wired network and they both respond to ping.cerbogx-page.png
And the PV inverter parameters:
AC load is not correct because PV production is not considered. Any idea of what could be the problem?
Multiplus-II
cramik avatar image
cramik answered ·
There is a switch and another device connected to the local network (seismometer). Rebooting these two devices solved the problem.
