ruzdic avatar image
ruzdic asked
Help if you have a Victron Isolation Transformer
I have a Victron Isolation Transformer 2000W (one of the old models with the built in fuses)
One of the blue Bingzi PCB mounted transformers has dislodged and was rattling inside and as a result the spec of the transformer has been rubbed off.
There are 2 there, one is 230V 50Hz/ 24V 10A and has a model T10-F80.
I need to know what the other one is so I can buy it to replace it.
If anyone has a Victron Isolation Transformer that can check it would be great.
All the Isolation Transformers should be the same (not the Auto Switching one).
My theory is that it is a 115v but can't be sure.
Isolation Tranformer
