jctibor avatar image
jctibor asked
Battery capacity on MODBUS
Hello everybody,
i am trying to read actual delivered capacity to the battery on MODBUS tcp from Venus GX in my C# application using victron multiplus + venux gx as setup. I am reading registers as follows in CCGX-Modbus-TCP-register-list-2.60.xlsx.
Battery Consumed Amphours (System) 845
Consumed Amphours 265
Deepest discharge 281
Last discharge 282
Average discharge 283
Total Ah drawn 286
Capacity 309
.. but every register returns me 0. I tried UnitID 246,247,100 ańd everything is the same.
Or Battery monitor BMV-700 / Victron Energy SmartShunt needs to be in the system?
Could you somebody help me?
Thanks
Modbus TCPbattery capacity
matt1309 avatar image matt1309 commented ·
What message does it give you on the Cerbo gx if you go into settings?
Settings -> Services -> Modbus TCP. It's likely that there's a mismatch in UnitID or register but the error message may give you a hint as to where.
If there's no error then maybe it is the fact that there's just 0 in the register and that an additional device is needed.
How are you monitoring battery in your system? I'd have thought that if the battery data shows in VRM/cerbo gx (by BMS or however you're monitoring the battery) that it would be in modbus somewhere.
jctibor answered ·
it is required for BMV-700 / Victron Energy SmartShunt be in the system.
Jiri
Modbus TCP Basics
