I just added two smartsolar mppt controllers and synced them with Victronconnect. I have a Victron Multiplus 24/3000/70 setup with identical parameters. Is it necessary to add additional hardware to sync these or will they play well together as is?
Not needed. But adding a Cerbo with WLAN will give you monitoring, remote control, software updates and other features.
Can the battery bank handle the total amps, if all three devices are in bulk mode?
Thanks, yes it’s an AGM 24 vdc 1600 amp house bank. The panels only add about 15 amps.
80 People are following this question.
