MPPT 100/50 undated firmware 4 days ago. Now will not charge. Do not know if related. System shows 65 volts in but no charging. I see current in PV input lines. Victron Connect is showing NO errors. I am stumped.
Have you tired a power cycle?
Disconnect pv, disconnect battery.
Reconnect battery, check settings, reconnect pv.
You could also try a reset to defaults and then re program after that. If it is still not charging then there may be an issue internally.
How did you measure current in the PV? with clamp meter?
I'm curious about your daily logged battery V's, Do you have something else charging at the same time?
You will need to try it with no other charge sources attached to the battery and with its voltage below the rebulk offset.
For a fuse to blow for no particular reason is unusual especially if it has been working.
Is the system networked somehow? Maybe remove it from the network. Something was upset firmware or set up wise after the firmware update.
There are further test instructions in this document.
After all those resets it should not be possible, but if not already done it, check in the MPPT settings if "Max charge current" is not set to 0A somehow and if the charger is enabled.
If you have done the pre rma tests in the documentation I linked and troubleshooting as far as you can, its time to take it in for a warranty claim.
Weird there is no error. Not totally weird that there is current in the PV side but not going down to the battery. The victron can short the input to prevent charge. But normally that would give a charger off state or error message as well.
All setting appear correct. Let me know if you see something wrong.
83 People are following this question.
