Hello! Is it supported and/or possible to upgrade node.js on a Cerbo to something more recent than v14.17.6? There are some interesting flows that I would like to add, but they rely on newer versions of node.
Hallo,
versuche gerade mit NodeRED (auf dem Cerbo GX) meine ersten Schritte.
Ein Frage: Wie kann man Nodes löschen? Ich habe die "node-red-contrib-knx-easy" und die "node-red-contrib-knx-ultimata" installiert und bekommen beim Löschversuch folgende Fehlermeldung:
Entfernen fehlgeschlagen: node-red-contrib-knx-easy.
Unrecognised module: node-red-contrib-knx-easy
Überprüfen Sie das Protokoll auf weitere Informationen.
Das Protokoll zeigt auch nichts erklärendes:
2023-09-19T08:42:17.603Z Entfernen : node-red-contrib-knx-easy
Was mache ich falsch bzw. was muss ich machen?
Hi, very hard to do yourself; I expect. But we’re working on going to a newer version. Will probably be part of v3.10
Hi, I am also looking forward for a newer version of node.js (for node-red).
Apparently node.js v14 LTS is End-of-life since end of April. I really hope the newer version will be implemented in the next version.
https://github.com/nodejs/release#release-schedule
@mvader (Victron Energy) the moste important knx node node-red-contrib-knx-ultimate need v19. v18 seams to be to old right now.
i managed to updating nodes.js manually to 19.9.0
Hi, I also have the problem, I want to use KNX Ultimate and I need node.js 16 or higher. On my Cerbo I have version v3.01.
What option do I have?
As written multiple times above this is a summary of the available options:
48 People are following this question.
