How can I block sending excess energy to the Grid?
Anyone know the configuration?
ESS is installed.
Marcin W.
ESS is installed.
Marcin W.
Go to ESS selection in Remote Console.
Next go to "Grid feed in" selection.
Select "Limit system feed-in"
Set the limit to ZERO.
I think, if you deselect "DC-coupled PV - feed in excess" MPPT charger will not supply the loads. It will only charge the battery.
81 People are following this question.
