reijo_ruotsala@hotmail.com avatar image
reijo_ruotsala@hotmail.com asked
Why is my MPPT not charging?
Why is not my solar panel charging for last to days? When I disconnect the panel I have over 22V from it and when I connecting it back to the regulator the voltage drops to a little bit over 1V measuring whit a multimeter. The app is telling me about the same voltage that's in the batteries. Last two days it's been a lot of sunshine so that can't be the problem.
voltage
One would suspect a high resistance joint/terminal/fuse somewhere.
Perhaps reverse polarity connection, or faulty solar panel?
markus avatar image
markus answered ·
if you did not change anything on your installation and see these symptoms, there is a chance that the unit is broken unfortunately. It would be best to talk to your dealer.
Best Regards,
Markus
